Alphabet ANY Font Texture Creator Basic by SpaceRay
http://filterforge.com/filters/12045.html
IMPORTANT - Please, do NOT judge the filter fr om the Presets shown because the main use of this filter CAN´T be shown in the presets as it uses EXTERNAL images to work with ANY font
DETAILED INSTRUCTIONS FOR USING THIS FILTER
You must load the fonts (or shapes, objects or photos) inside the 5 ANY FONTS color controls and ACTIVATE the checkbox.
It does NOT have to be 5 different ones, you can use just only 1 (put all the five with the same one), or 2, or 3 and up to 5, just be careful of filling always all 5 color controls. See next post for hints and tips on this
See below on another post, a graphic description of the settings explaining what each setting does
Please, at the end of this post how the final font of your choice must look like
Here below I have used this Free Embassy font
You can use ANY language fonts, as for example I have used some Japanese fonts as shown here below (more information about this Japanese fonts and the ones I have choosen can be found here)
Will start first with the easier one that is the second one wh ere you do not to prepare it and can be used directly
2 - USE ANY PNG, PSD, or VECTOR FONTS
There are already available thousands of these kind of fonts on internet, many are free and many paid ones, one of the best and excellent and awesome quality paid ones I have seen are the Handmade Fonts
The PNG Font format can be used directly without any previous preparation
The PSD format only needs to be converted to PNG with transparency with the software of your choice
The VECTOR fonts must also be converted to PNG with transparency although is different way than with PSD
One very good and excellent quality Example of paid and commercial vector fonts are these - Vector fonts examples
Will put more possible FREE and legal sources for fonts in another post below
1 - USE ANY OF THE SYSTEM FONTS WITH THIS FILTER
Here is the instructions to make your images to be used with this filter,
I know that this NOT an easy way to do this and needs time to make it, but is the only way I personally know, if you may know any other simpler and/or easier, please, would be good to know it and you can put it here
HOW TO CONVERT AND PREPARE SYSTEM FONTS ( the ones you can type with the keyboard like for example opentype or TrueType or any other similar) INTO INDIVIDUALLY EXTERNAL IMAGES TO BE USED WITH THIS FILTER[
Before you can use the font that you want you must first convert each letter to individual image
The way I have done it myself is with photoshop, sorry that I do not know any other alternative way with another software, if you know it, feel free to put it here if you want.
I know that maybe after reading the following 10 steps you may think that this NOT an easy way to do this and needs time to make it, and is a hard work, but really although it seems a lot of work, when you start making it, you will see that is not so hard and does not take much time, I have converted 5 fonts in less than 5 minutes.
1 - Choose the font you want to convert. There are available MANY sources for fonts, one of the sources is websites with font collections like for example Dafont.com, Myfonts.com or YouWorkForThem.com (there are lots more websites available), in these 3 there are available free fonts and also paid ones, the best one with more free ones is the first, dafont
2 - the font must be installed and available inside Photoshop
3 - make a new document in photoshop with the size that you want to make each individual letter, it is not needed to make it big, maybe 1000 x 1000 is enough. Put transparent background option in the new image instead of white.
4 - now put the first letter filling most of the space available, for example, for the Embassy font above example, I have used a 360pt font size. Very important is to make it white otherwise it will not work. You do not have to care putting the letter in the letter or not, it only needs to be inside the square, it will be automatically trimed later.
5 - make a new layer and then rasterize the previous text layer below and switch it off so it will let you see your next letter better.
6 - put the second letter in this new created layer, as said, is not important to center it, and do not have to be in the same place as the first one. Now make a third layer and rasterize this second letter
7 - Repeat points 4 to 6 until you have made all the letters you want, and so on until making all the 25 letters in 25 layers that is the maximum possible. The minimum letters needed is only 5, so you do not have to make all the letters if you do not want.
8 - Now make all the layers visible
9 - Go to menu File--> Scripts--> Export Layers to files...and configure it in the samer way as it appears in the screenshot below. When finished click RUN, and then all your font layers will be trimed and saved into the choosen folder
If this maybe do not work for you or do not understand it, there are many tutorials showing how to export photoshop layers as files
For example this one Tutorial of exporting photoshop layers to individual PNG files
10 - now you are ready to load your newly created PNG fonts into the color controls of the filter
The final font images must look like shown here below that you need to make to be loaded with this filter
EAdams
I wanted to try out this interesting filter, but I think that despite your detailed instructions, I am doing something wrong. I chose a free butterfly font and made individual PNG-8 files out of 4 different butterfly characters. The transparency is preserved in these files.
I activated the "Activate Any Font" checkbox and loaded the 4 PNGs. This gave me a transparent cut-out of the shapes surrounded by a square white image background.
Is this the expected result? I was hoping for the butterfly shapes to appear with a transparent background like your letters appear in the default preset.
I do notice that in your default preset (with no external shape loaded), if I deactivate all the checkboxes "Letter Shape A to E", "Letter Shape F to J", etc, the letters render the same way as in my butterfly example.
I have some more feedback on this filter, but I am interested in knowing if I can get my external font to display differently first. smile:)
I am very sorry EAdams that I have seen that I have uploaded the wrong filter smile:( smile:blush: and this one could not show right the transparent background, I have just sent the good and fixed version and also have made a new better instructions page more detailed to avoid any possible problems.
Please, be aware that any loaded Font must be White with transparent background, see an example at the end of the instructions.
EAdams
Thanks very much for trying this filter, and I agree that this can be a very interesting and cool filter that is different to others filters as this is based on external fonts, shapes, objects,... etc. that you can load in the 5 color controls and I can´t show this in the presets.
EAdams
What these checkboxes do is actívate the Invert shape option, so all the transparent background is converted to solid color, and the solid color Font to transparent.
I have now modified the text of these settings to Letters Invert so it is more clear
The reason to put this is to have more options and posible weird designs
EAdams
Hi SpaceRay, thanks for updating the filter and the instructions! See a first successful render:
I have many thoughts about this filter but not much time to organize them right now, so please excuse the chaotic presentation. Please consider these only as my own personal thoughts and not as a request or suggestion to change anything!
Some Filter Forge filters work best with simple shapes rather than with images. It is a major shortcoming of FilterForge that it doesn't include a few simple shapes for filter authors to use in their filters' default previews. They can only preload one of the default images or construct a simple shape within the filter itself.
In effect, this is what you have done with this filter by including the entire alphabet from your other alphabet filters. I understand why you did this (it is the only way for you to show in the default preview how any letter of the alphabet can be used in the filter).
However, the stated purpose of this filter is NOT to have to use your in-filter constructed alphabet, since those users who want to use it can do so with your other filters. I haven't compared your three similar font texture filters in detail, but it seems that this filter can do what the others can do but has the added functionality of being able to deactivate the in-filter font characters and replace them with custom shapes. Thus you have created an "ueber-filter" which can do everything. The number of alphabet controls is daunting, and unnecessary for someone who only wants to apply their own custom shape.
"Custom shape" is a key concept here. In truth, this filter is NOT an "any font" filter, but an "any shape" filter. The fact that it is possible to convert a font character to a shape doesn't change that. The idea of being able to use "any font" arose from your previous filters with the in-filter constructed font, but this fixation with the font idea is obscuring the fact that this filter is something completely new and wonderful.
As stated above, it is unfortunate that it is not possible to use an external shape in a default preset. But it would suffice to include only one simple in-filter shape to create the preset, and instruct the user to load his/her own custom shapes. It wouldn't be necessary to include the entire alphabet. This would simplify the "Shape texture" filter while highlighting its versatility.
Let me leave a critique.
Chapter 1: The good stuff
Some positive things! Some nice organization with the controls, lots of them! Way too many. But ok nice job organizing things and writing up documents n stuff.
Chapter 2: The Part Where I Get Critical
By far, this filter has been the weakest of the series. Let me break it down into chunks.
1. You title it "Alphabet ANY Font Texture Creator Basic" which is kinda misleading because "any font" = "any image". You can import symbols, pictures, fonts... yeah anything image based. So this really takes away fr om the whole point of this filter's purpose: to splatter fonts everywhere. Your first version of this actually was the best of all editions. The reason being that it generated fonts internally via ThreeDee's snippet, and it just worked. It was special in that it did that.
Basically, what's the point of your "font" filter after all when you can load anything?
It seems like your filter is lost in its own identity. Mixed up between "can load any image" but the author prefers to use it with fonts.
2. This filter = just a bomber with extra things dangling on it. It's basically a filter loosely tied together by a thin piece of string. ThreeDee's work being fed into the bomber is the only thing that really matters in the entire filter. So what's the filter after all? Just a bomber?
3. At the point you're instructing people how to use the filter, your filter is overly complicated. People expect things to be intuitive, especially programs like FilterForge. That basically sets the tone for the whole thing. Nobody reads instructions. People rather just play with sliders and generate stuff than read a 1000 word introduction to how to use a simple filter.
4. 3 versions later and you're still fixated on the same ideas since several years ago. It seems like the same thing submitted again... and again... and again. This is wh ere I feel like I need to pump some creative spirit in. How about a PAINTERLY version of the filter? Or something that's really "designed" and fashionable rather than just bombing letters out? See, to me, this filter needs to seriously evolve. It needs to become cooler but it just can't because it doesn't know how. You need to seriously challenge yourself and move on beyond doing something simple like this.
Chapter 3: The thing about it all.
It can improve. Every aspect of it can improve.
Remember, push forth, rebuild, and take a good look at what you make. Rebuild again and again and again if you need to. What makes a good filter is a filter that works to our expectations. In this filter, it's seriously obvious where your flaws are so it's your chance to deal with them, face some challenge and give it some time.
[Edit]
Kinda cleaned up the argument. I think the issues have been pretty obvious. I guess what hit me was the fact that it's really just a bomber in the end.... Seems like the filter's documentation is quite a stretch trying to explain it's purpose and otherwise. To be fair, you've been working on this for some time and the pictures do prove that you got a vision, but the filter itself proves too simple as a final piece of work.
Thanks EAdams and Skybase for your comments and all you have written, I will answer you later in another post as I would love to answer you now, but regetably I do not have enough time to do it now, sorry.
Be aware that this is the BASIC and simple version, and maybe is too simple for someones, so here is already available the extended and more complex version with more features and greater possible customization
Alphabet ANY FONT Texture Creator Extended Seamless
NEW UPDATE IS AVAILABLE FOR THIS FILTER
1 - NOW IS SEAMLESS, I forgot to activate it when submitting
2 - Added Individual activation of each one of the ANY Fonts.
3 - Organized better and more ordered and logically the settings to use them easier, and separated also the ones that are not relevant to the ANY FONTS and can ONLY be used with the internal fonts
4 - Fixed some settings names.
I kinda wish you'd respond by acting upon it. It seems like we exchange words than we actually accomplish something. The only reason why I'm leaving critiques around is because you've been here long. You've asked countless times for advice on using the program, and you've got answers. Just a side note: a lot of the advice you receive are really good pointers about building filters, about standard practice, and also a measure of quality control. I think you've done your part following some of them, but it seems like you either don't recognize the value of it or you forget about them.
Just kinda sad really.
[Edit] Removed some of the other thoughts I had. I think I need to keep the discussion straight forward. I think I'll put some of it on whatever other thing you might write up.
But yeah... I guess I can give a helping hand with something like this. You seem to be pretty much stuck making filters these days.
38 unregistered users.
