Filters: 712
Radial broken zoom by Jarfil
http://www.filterforge.com/filters/12006.html
Filters: 712
Interesting filter.
An idea to develop it could be splitting every sector in more parts, like in this picture :
Cool and well done filter, like it
Well done the outlines added to each part
This remembers me the other similar filter made awesomely by uberzev called Zoom Shatter
Although this one is different than uberzev´s filter, as it work in a different way, and the zoom is more real, and do it in a different way, less than a shatter, keeps the center untouched, has blur and disortions added, so is a well done and good displacement effect, I like to see this filter as an good alternative and like it much too
Yes, this could be a great idea to be able to split more each sector in more parts
Like how you can customize the how much of the center is untouched and how much blur you want for slices that go into the center
and here is a how you can break an engine but keeping the center untouched smile:)
And here is how a simple red anemone flower with white center can be modified with this filter to create an unusual effect keeping the central part but breaking the surroundings and expand also the center and duplicate it
and here is how is the original photo compared to the above full effect
And what is good also is that you can have optionally outlines to the parts and get a different effect
And all the above examples have been done with only 12 slices, but you can put more if you want, this one here below is with 37 slices
All the above examples have the slices straight but you have the option also to bend the slices, here for example I am using 16 slices with Swirl slider with a 69 value to make a spiral like effect
Be aware that the Swirl with a 50 value is the total straight so you have to go above or below 50 to bend them to either side
and reducing Swirl to 50 (equal zero value) and using the Distortion with 26 value and 12 slices I got this
And the same settings as the above example but with 35 slices
now using all the settings differently and nearly all active mixing them I got this
This is using Blur zoomed and not using Blur Original
This one is all the same as the above one BUT:
This is not using Blur zoomed and is using Blur Original
Going back to all at zero and rising the Slices to 100 and Zoom 100
And all the above examples I have put are using a Zoom value between 50 to 100 so that the slices fill all the viewable space until reaching the external border
Here I have done one with low zoom values (here is 11) so the slices are kept just outside of the flower shape
And using the outlines in black, and as the background is also black you can´t see the ones that are there but mixed with the background same color
And the above one here maybe looks too spiky so you can customize it better using the blur setting and zoom to joint together the borders of both
Now for something different using full blur to make something more elegant for the surrounding center
And after 14 examples shown above I put a very different one, and is that this filter can also be useful for making radial stripes backgrounds bluring all the original and the slices to get a soft background
The 15th and last example is based on the above one, but using a colorful background and much less blur applied so there is more sharper slices
Filters: 712
Very interesting examples Thanks SpaceRay.
Today I made a new filter based on the idea to split a photo like the first picture that I posted. It is composed of 5 circular areas that can be independently split in sectors ( this way every area can have a different number of sectors ), rotated, deformed, blurred. I also added some black backgrounds below every area that, if faded, may give a shadow or 3D look to the image.
I firstly made a simple filter, then a surface filter.
I'm going to post one or two versions tonight.
Filters: 712
Here you can see two low-resolution presets from the simple filter :
Then two low-resolution presets from the surface filter :
One of these days I'ma havta upgrade (from V1 ha-ha). And it's because of filters like this, cool stuff. smile:)
ddaydreams
Frank Hawkins
nice work smile:)
39 unregistered users.
