hexascope true 60 degrees by tornadotwins
http://filterforge.com/filters/11986.html
I like this one and is a good idea and I have not thought to make and hexagonal kaleidoscope and is good that you have done this, but I prefer to have the egdes defined and not with a gradient as it was shown this morning, when this filter appeared for the first time and now it has been changed all the presets, and none of them is showing the full hexagon shape as it was shown before.
I wonder why you have deleted all the beautiful presets you had before and only leaved 6 non hexagonal presets (3 are made randomly by the submit wizard)
I mean although I also like the star shape or round shape you have already shown, I still prefer more the full hexagonal shape you can also do, because this way, you can make many different results and then you can tile the different hexagons you could make very easily in a graphic software.
Like this one shown here
The good thing in this filter (as in may other kaleidoscope filters) is that it can have thousands of different variations just and only by modifying the Offset X and Offset Y and it will give you lots of beautiful combinations
And the big difference in this filter from other kaleidoscope filters is that for me, is the first one that shows the idea of SHAPE BASED results instead of filling all the available space as it happen with all the other ones.
And not only you can make a hexagon kaleidoscope shape, also a kaleidoscope circle, that you could also make many different of them and then join them in one artwork in different sizes and colors
Also good to try different push size settings
And there is even more possible kaleidoscope that could be done, here is a 6 circle shape modifying the spikes setting with a high round setting
And using a low round setting with high spike you can get this kaleidoscope star shape with round points ends
And also this other Kaleidoscope star shape with sharp points ends
And with maximum Scale Crystal value and modifying other settings you can get this nice shape
With nearly all maximum or minimum value and using a low soft setting
And then again modifying some settings you can get even another different shape different to the other ones aboves and is like thin sticks ordered like in a star shape as seen here
And reducing Scale crystal and soft settings to zero and modifying the other settings you can get another different shape with full edges
And making slightly thicker than the shape here above, and modifying the settings I got this kaleidoscopic little flower like
and this other different one
tornadotwins
quantum girl 686
glad you like it
im fixing the presets too
Madeline
And with the flower like shapes inside the full circle shape I got this other example with these settings shown here
And here is the last example to show the love for this filter with this heart like shapes inside a kaleidoscope circle
And as the hearts in the example above are not clearly heart shaped, I put this other one using the soft edges to show the love for this filter smile:)
