EAdams
Dividing Frames by inujima
http://filterforge.com/filters/11922.html
EAdams
I love this filter and the variations it offers! Great job!
OH! YES!!! WOW!!! I also love very much this filter is FRAMETASTIC!
Excellent version and very high quality and easy to use as usual from inujima
unique.
ddaydreams
Frank Hawkins
Fun filter, thanks much for sharing it. smile:)
I have been using this filter more and I REALLY LOVE IT MUCH!!!! smile:ff: smile:loveff:
Is really well done and clever done
Thanks very much for making and sharing this
I wonder how do you change and customize the color of the overlays?
As the only control available is the color variation setting, and you can only choose the frame color and line color but not the colors inside the frames as these colors are made with the perlin noise, tone curve and assemble.
Would be good if there could have a switch to use the coloring method available now that is good, but also one that you could define and customize
inujima
I selected just really needed controls to avoid complication by too many controls.
If you need other color making method, you should customize this filter.
Below is a example one of color making method.
Addition, without customizing the filter, you can blend layers using graphic software like photoshop.
This filter has Output Mode slider for outputting these images separately.
Thanks Inujima, will see what I can do
13 unregistered users.
