Simple Lens Flare by Vladimir Golovin
http://www.filterforge.com/filters/11749.html
Like this Lens Flare filter that makes a very good and realistic lens flare with so many rays realisticallly coming from the center and then fade as they go away, and great the rings options as it adds much to the effect, as the lens flare alone would not had been the same.
And you can combine multiple rings colors to get very different effects
Good idea to have this lens flare in the FF library, as there has been some threads and posts about making lens flares with FF, but until now there has been none of them available.
The only thing I miss is a color control for the center color (or maybe 2) to be able to have another color other than white, so also you could do others effects.
