WOW! Beautiful texture you can make with this. Well done
softhunterdevil
check my filters
Filters: 11
This one is very nice
check my filters please
JayScarface
Filters: 4
FilterForge зависает при генерации данного плагина.
Intel core i5 3570
GeForce GTX 970
RAM 16gb
FilterForge hangs while generating this plugin
Intel core i5 3570
GeForce GTX 970
RAM 16gb
I do not know if the translation is right (done with google translate) but this is a filter and not a plugin, maybe you may be saying that it hangs while using Filter Forge as a plugin with this filter
You have to give more information about this to help, is also needed to know
if is with Windows or Mac?
If used as a plugin what is the host used?
Does it happen only with this filter and no other?
What is the resolution of the result that you want, or what is the resolution of the source image you are using?
Have you tried to restart your computer and try again without any other software?
Does it hang if you use it on the standalone version?
ceramix4
Hi SpaceRay , i know russian language and get the same FF freeze about said JayScarface during use this filter, unfortunately. But it occur (for me at least) only if i use filter with my own image (large resolution). With default FF picture this work properly.
Besides, during freeze here not occur CPU usage (i.e. not running any processing) nor extra RAM usage - both moments in calm. But for just in case im wait about 15-20 minut - the same nothing. Process just stop about 10%.
FF standalone (not PS plugin), v5009, win7 64bit
I am also finding that Filter Forge freezes with this filter. I select the filter, open it in the filter editor, click some of the components, and click "cancel" on the bottom right to exit the editor. By then, it usually freezes.
This is with the default "lifesaver" image, same version/OS as Ceramix.
It may have to do with the map scripts that Velho uses in this filter.
ceramix4
I else discovered just now - i tried again different built-in FF images - work properly for me as i already said, but when i push to randomizer button (in settings) then also it freeze, the same at about 10% of render, it was one of default images called "Garlic".
11 unregistered users.
