Hello, I like what you have done here, and it looks like it is like woven and stitched in some way.
Although I would really recommend that you do two very easy things (without having to entering into Filter Editor)
1 - LIGHTING - Please, go to to the Lighting tab and rise the brightness for each of the presets as they look too dark and does not really shown the power of the filter, and you really can´t see what is there. I see that all the presets needs to add more Lighting.
For example, in preset 5 when going to the Lighting Tab, the default value for Brightness is 22, and if you rise it to 190, you make it really shine and you can see it much better. I would put around 190 value in all of them.
2 - SEAMLESS TILING - Although this is something optional, and not bad, I would not recommend to put active by default the seamless tiling on every single preset, because seamless does not work with non-square images or probably better said, the seamless tiling must have an integer aspect ratio to work, so if you load any other image that is not this way, you will get a FF message telling you that you can´t use it.
Borrus
Filters: 10
thank you very much for your advice - i will update shortly, accordingly!
Kevin Worth
How come they are all still too dark. Nice filter though Borrus.
Borrus
Filters: 10
Well, the presets aren't as dark as they were before - you're probably right they could do with some more adjustment. I can't change them anymore though - my trial period has expired. As SpaceRay commented, if you want them lighter still, you could just up the brightness in the lighting settings of the preset. Glad you like it though - thanks. smile:)
Kevin Worth
o.k. thanks Borrus, I'll adjust it myself.
15 unregistered users.
