Color Temperature (sRGB) by ThreeDee
http://www.filterforge.com/filters/11596.html
This is neat, could you explain the "science" behind your node setup? (not the color choosing script, although if you could do that too that would be cool. Is it just a blackbody radiation curve?) smile:)
Yes, the script outputs black body radiation curves in sRGB color space.
The color temperature shift may not be scientifically accurate, I just used logic as to how that color light should affect a neutral image. You probably cannot correct an incorrectly lit photo with this filter -- it is likely more complicated a matter -- but at least you can introduce a specific color temperature to a correctly exposed photo.
