Techdraw Mapscript X10--v1 by GalaxyMeridian
http://filterforge.com/filters/11590.html
This is quite a way of drawing a picture, but I'm impressed! smile;)
Leo Fernevak
Leo Fernevak
Filters: 14
Thanks Skybase.
About the previews, it seems I should have turned on the anti-aliasing effect before I submitted the filter, since that would have removed the pixelated result.
I wanted to create a script which makes it easier for users to design human faces, spaceships, animals, flowers, etc, without too much complicated structure.
The old method, which is faster to render, takes about 0.2 - 0.25 seconds per curve:
(For example, Quasimondos snippet from 2006, or uberzevs' from 2013:)
http://www.filterforge.com/filters/679.html
http://www.filterforge.com/filters/1619.html
However, if you wish to design a complex design, you need plenty of curves connected like this. It can easily grow out of proportion, and for most users, that will be discouraging.
My script takes about double the time of the fast method, per single curve. Although, when you connect 10 curves to my mapscript, it is not much slower than using the 'fast method' with 10 curves. So the more curves you connect, the less of an effect on overall speed is noticed between the mapscript and the fast method.
For designing faces and similar designs, I particularly made the snippet and script Curveblend Drawing, since it combines one normal curve with an inverted curve, which makes for easier bezier-design:
http://www.filterforge.com/filters/11585.html
----- Mapscript information -----
Note that the 10 different curves are rendered in separate layers.
The higher layers will render on top of lower layers:
Layer 1 - Top layer.
Layer 10 - Lowest layer.
Leo Fernevak
Leo Fernevak
Filters: 14
The script error is now corrected in the upcoming update to version 1.1.
Leo Fernevak
Leo Fernevak
Filters: 14
Update to version 1.1 has been submitted to the library and will appear this week.
New features and update notes for version 1.1:
- One bug corrected in the script.
- Three new modes added: [Mode 4] - [Mode 7].
- [Mode 4] now has shading capability.
Note that the shading function is yet only active for [Mode 4].
This is because the shading function steals extra rendering-time and I want to keep the other modes as fast as possible.
- The previous [Mode 4] has been moved to [Mode 5].
Also an issue with an inverted Y-axis has been fixed.
- [Mode 6-7] can draw a combo of a normal and inverted curve.
The inverted curve follows the normal curve's Y-axis.
Note that in these two modes, every ODD curve is a normal curve, and every EVEN curve is an inverted curve. This makes it easier to draw bezier curves on top of pictures and combine two curves into a complex figure.
Example of [Mode 6-7]:
[Curve 1] + [Inverted Curve 2] forms a combo.
[Curve 3] + [Inverted Curve 4] forms a combo.
Etc.
- Images can be imported both for the background color and design texture.
- The mapscript has been updated with informational notes.
A few renders of previews in version 1.1, using the shading in [Mode 4]:
Leo Fernevak
Leo Fernevak
Filters: 14
Preview from the combo-modes [Mode 6-7].
These two modes are ideal for shapes which are not symmetric on the vertical axis, for example: eyes, lips, architectural details, spaceships, et cetera.
In these two modes, normal curves are combined with inverted curves to form a shape.
The lower curve always follows the upper curve, but can also be blended and 'sink' into each other to form more advanced shapes.
Later I will also add a shading capability for these combo-modes.
45 unregistered users.
