| Posted: June 23, 2013 6:08 pm | ||||
Cool and good effects, will have to see how this works
Congratulations, great work, and great to see new filters from you I had before an idea similar to this one but the result was not as good as these ones, well done |
Thanks SR and if you want, it would be kind to see some images from you with this filter. Maybe you can create things that I did not see with this filter. I always appreciate what users can do with filters we upload.
visit https://gisoft.ca |
| Posted: June 23, 2013 9:46 pm | ||||
Thanks to you for making and sharing this filter. These are the things I have created when I have seen this filter By the way one suggestion, is that maybe it could be possible to add a scale component for the images that goes into the threshold as it would be easier and better to position the photos inside the geometric shapes and customize them, as now you can´t and they the whole available space. |
| Posted: June 24, 2013 1:01 am | ||||
| Posted: June 24, 2013 1:02 am | ||||
| Posted: June 24, 2013 1:05 am | ||||
| Posted: June 24, 2013 1:06 am | ||||
| Posted: June 24, 2013 1:08 am | ||||
| Posted: June 24, 2013 1:09 am | ||||
| Posted: June 24, 2013 1:10 am | ||||
I have seen this music video
will.i.am - Scream & Shout ft. Britney Spears At beginning in the second 10 there is this image (if this image can´t be seen, please see the one below this post)
I like this and thought that this could be possible in FF, and then I remembered that this was done already before in this wonderful filter, but found that was not possible to get just 3 triangles, the Add/reduce Line does not work as expected, as with value 2 is already appearing 5 triangles, and you can´t put less than 2, so I went to the filter and found that removing the remapping of this setting and activating mirror checkbox I could get 3 triangles with a value of 2 |
| Posted: August 26, 2013 12:20 am | ||||
| Posted: August 26, 2013 12:25 am | ||||
Sorry I was wrong of what I said above, there is no need at all to modify the filter in any way and remove the remapping, with the original filter just put Add/reduce Line value 2 and the click on the mirror checkbox to convert the 5 triangles into 3 triangles.
ALso in this other video will.i.am - This Is Love ft. Eva Simons on 2:50 appears this shown below, although in many other parts it appears also but not full screen |
| Posted: August 26, 2013 12:41 am | ||||
