I have found two problems with the Top Secret by ThreeDee awesome and amazing filter and did not want to put this in the main filter thread as do not want to spoil that thread with this problems.
I have used this rectangular photo of a city and got some weird results
As you can see above the right side is cut and not showing all in the same way smile:?:
Changing only and just the "Progress" setting from 77 to 94, so it reaches the bottom of the image, and keeping all the other settings the same, the problem is solved and works right and so all the whole image is affected.
But I do not know why and how happens the above problem and why is happening smile:?:
Does this have something related to the XY ANCHOR and some missing "Image Bounds" setting in some component?
But also this error gets worse and is more noticeable if you use the "Size pixels" slider as can be seen here.
In the first example above, the "size pixels" setting is at the top right maximum
And it happens also when you load a vertical rectangle BUT is worse, as it also appears that the image is cut with a knife and offsets all the strips
And here in this other example can be seen much better how the strips are cut with a sharp line
and modifying the settings can even appear 2 line cuts
I still have not found a way to remove this cutting lines as all the settings I have tried does not remove them unless you can use the progress raising the image until the line cut is not shown so it becomes invisible, but really this is no solution.
Yeah, that looks like I've missed some XY anchor setting somewhere.
I have found that there are around 7 components that do not have the "Image Bounds" XY ANCHOR activated and are offset and free gradients components
Happily this solves very well the problem that happened when using the "size pixel" and the progress slider, and now they do not get cut at the bottom smile:ff:
BUT the bad news is that the Line cuts with large vertical images as the one above still happen although is less noticeable, perhaps I still have missed another component that still have not been changed
