I wish we could give an Editor's Pick to this filter but it's way too slow. I'd suggest to replace some noises with Perlin -- it's way faster than any Worley-based noise.
This was one on my list of filters that I need to update..I will try to make it faster now that I am inbetween filters smile:)
Well I did try to make this faster with some Perlin instead but it changes the look dramaticly. Any suggestions would be helpful to try...Meanwhile I will try other things also..
voldemort
voldemort
Filters: 649
good things come to those that wait--I think its quite nice as is true alieving the build time would be nice but I would rather have a quality end result then comprimise it for speed sometimes its worth the wait even though it can get frustrating
Well I am closer to the solution...I did get the speed up a whole lot..I am using this filter in IMAGE result rather than the Texture result..For the lighting I am using the Soft Lighting Method. Hopefully I will have it complete and looking good in a day or two..But should I update or call it no.2 here is a pict since it is a little different.
55 unregistered users.
