Clint
Clint
These look great, Scazz! I'd be interested to hear how FF can do Batch Rendering. I can't find any function anywhere in the software to get it to perform this. Could you please enlighten me? Thank you! And thanks for these filters! smile:)
Scazzino
Filters: 4
Hi Clint,
DLI_FireFlow, DLI_WaterFLow and DLI_LavaFlow can all be animated and rendered with the FilterForge batch renderer. The batch renderer is a standalone command line application that's included with FilterForge. On the Mac it's in the FilterForge App folder and it's named FFCmdRenderer. It can basically render a filter over and over while cycling (or randomly changing) through a set of values for any of the filter's settings. Filters designed for this, like all my "flow" filters, typically will have a time setting that can be used to cycle through a seamless loop. To make using the batch renderer easier I use the front-end GUI interface for it FFBatchMaster for Mac OS X.
One tip, if you want to use the transparency available in DLI_FireFlow you must specify a blank transparent source image for the batch render, otherwise it will render the filter over a white background rather than a transparent background.
I may do a blog post with a quick tutorial on my DreamLight facebook page if there's enough interest, and when I have some spare time.
Here are some links that should help get you started.
My DLI_Flow animated filters
http://www.filterforge.com/filters/au...page1.html
Filter Forge Command Line Renderer
http://www.filterforge.com/more/help/...derer.html
http://www.filterforge.com/forum/read...0&TID=7051
Batch rendering and alpha transparency?
https://filterforge.com/forum/read.php...MID=115947
Scazzino
Filters: 4
BTW: Here's my DreamLight facebook page. I have a few animated previews of all three "flow" filters posted there if you'd like to see what they look like animated.
https://www.facebook.com/DreamLightIncorporated?ref=hl
Burt
Random Old Guy
Good looking filters. Haven't tried the animation, looks like it could be useful. Will keep an eye out for your tutorial.
Scazzino
Filters: 4
Thanks for the positive feedback guys!
Knight81
That you can change the time is amazing. Should be on all filters so that you could make an animation of them. smile:)
The-any-Key
A decade later I turned this into an animated filter. Here's the filter in FF13, the only change is replacing the Time slider with Normalized Time.
Default preview animated: https://duim.com/animate/fireflowB.webm
Right click to loop
DLI_FireFlow Animated.ffxml
