Ozmandias
Posts: 88 |
| Posted: February 10, 2013 9:51 am | ||||||||||||
Sharandra
| Posted: February 10, 2013 11:04 am | ||||||||||||
Sharandra
| Posted: February 10, 2013 11:18 am | ||||||||||||
Ozmandias
Posts: 88 |
Hey! That looks GREAT! I didn't see your filter in the library.
| Posted: February 10, 2013 11:20 am | ||||||||||||
Sharandra
It´s not in the library, just click on the attached ffxml file.
Edit: If it doesn´t open in FF automatically, move it to your my filters folder. (Users/ YourNAme/AppData/Roaming/FilterForge 3/MyFilters on windows) |
| Posted: February 10, 2013 11:21 am | ||||||||||||
Ozmandias
Posts: 88 |
Oh... well that explains why I didn't find it. That makes me wonder how many other great filters are in existence but not available in the library. I'm new to Filter Forge (just bought it a couple months ago) so am just learning. Thank you so much for making the filter available here. I think it's the closest I'll get to what I am looking for and even without the controls you spoke of, I'm sure I'll get some fantastic results. |
| Posted: February 10, 2013 11:47 am | ||||||||||||
Sharandra beat me to making it
| Posted: February 10, 2013 12:12 pm | ||||||||||||
Ozmandias
Posts: 88 |
Please do, Skybase!
I just tried out Sharandra's and it looks really nice. She's (?) right though, there are very few controls. Would it be difficult to get the filter to follow the lines of the image instead of just all strokes generally going horizontal. What I mean is... if I have a photo where the subject is vertical but the background flows more horizontally, can the filter be made so that it is smart enough to place the paint strokes on the subject in a more vertical fashion and still keep the strokes on the rest of the scene flowing horzontally? (Hope I explained that understandably) As I mentioned, I'm new to FF so my expectations/hopes may be way too high and out of the realm of possibility. |
| Posted: February 10, 2013 12:24 pm | ||||||||||||
Sharandra
Glad I could help. Here is a version with an optional frame. Btw, you can use the size slider for smaller brushstrokes.
We all got our secret treasures!
Maybe I´ll tweak it a bit and submit it sometime.
Yay! Wasn´t hard tho, as I already had it. It was an experiment I did a while ago. Originally it was just plaster/paint on a wall And I´m curious with what you came up with, so yeah post it! |
| Posted: February 10, 2013 12:27 pm | ||||||||||||
Sharandra
With a different approach that should be possible. Something like the Van Gogh Flow Filter. Let´s see what Skybase did. Edit:
| Posted: February 10, 2013 12:30 pm | ||||||||||||
Sharandra
| Posted: February 10, 2013 12:49 pm | ||||||||||||
Sharandra
Now you know tho, why it´s not in the library
I bet Skybase comes up with something that flows with the image |
| Posted: February 10, 2013 12:53 pm | ||||||||||||
Ozmandias
Posts: 88 |
That was fast! I'll try it out... thanks!
Me too.
Not sure I understand what you mean.
Hope so! |
| Posted: February 10, 2013 1:46 pm | ||||||||||||
Sharandra
Same version but it needs a selection. you can change the brushstroke angle on the selected part.
It´s really tricky to let FF know the direction of objects in an image. Paintstrokes 2.ffxml |
| Posted: February 10, 2013 2:23 pm | ||||||||||||
So I reopened that filter project after a couple days of inactivity! Didn't forget... just the problem is that... well now it looks totally different from the picture that was posted as reference. heh. This is what I get for working at 4 am in the morning.
I'm going to add some controls and post it here. The filter was made in version 4.0 beta, so umm... if you have 3.0 The preview scale is mildly biased so I'm adding an option that'll make the filter output scaled properly so it visually appears the way the filter's been imagined. Although this feature may come in later! |
| Posted: February 21, 2013 9:20 am | ||||||||||||
| Posted: February 21, 2013 11:49 am | ||||||||||||
| Posted: February 21, 2013 11:51 am | ||||||||||||
Ozmandias
Posts: 88 |
Rats... guess I won't be able to use it then. I just bought version 3 and have no intentions of upgrading at this point. Too bad because it's looking good and with more tweaks, it'll be a winner. |
| Posted: February 22, 2013 5:26 am | ||||||||||||
Well... I can always downgrade it by remaking it in FilterForge 3.0
At this point the base material's pretty much done and it's a relatively simple filter. Just the numbers have to be the same which shouldn't be hard to re-make |
| Posted: February 22, 2013 10:32 am | ||||||||||||
Ozmandias
Posts: 88 |
OMG... that would be awesome! I'm sure there are other folks out there that don't have FF4 and would also appreciate this in an FF3 compatible version. THANKS, Skybase! You are SUPER! |
| Posted: February 23, 2013 7:16 am | ||||||||||||
Been a while... so I was working behind the scenes... quietly just reconstructing the filter from scratch. My daily life is ... pretty awful already
Either way I'll submit this to the library with final touches but I thought I'd first put it here anyway. Current render times hang around 32 seconds without the anti aliasing and it looks perfectly fine without it. Enjoy! Painterly.ffxml |
| Posted: March 5, 2013 10:54 am | ||||||||||||
Never mind I submitted the latest version with more features in the library!
| Posted: March 6, 2013 6:49 am | ||||||||||||
Ozmandias
Posts: 88 |
THANK YOU, Skybase! I will try it out and post one of the masterpieces it creates!
| Posted: March 6, 2013 5:49 pm | ||||||||||||
Ozmandias
Posts: 88 |
I'm not finding in in the library. Can you provide a link? |
| Posted: March 7, 2013 1:28 pm | ||||||||||||
The queue apparently just updated last night so here it is finally: http://www.filterforge.com/filters/11275.html
I forgot one feature. |
| Posted: March 11, 2013 7:42 am | ||||||||||||
Ozmandias
Posts: 88 |
Yes, I noticed that it finally appeared. I went ahead and downloaded that one and will try it out. I will watch for the update.
Thank you so very much for creating this filter. It appears to be very close to what I was looking for. |
| Posted: March 11, 2013 8:34 pm | ||||||||||||
