Burt
Random Old Guy
Burt
Random Old Guy
Well I uploaded this today. The presets look different than they did on my laptop - not sure why and I just got a private message from someone saying the filter doesn't work. Not sure if that is spam as it works for me, and I don't see any place around here with a private message inbox? Unless I'm blind I checked under 'More' and on the forum.
Sharandra
Filter Forge Addict
I just downloaded it and it works for me, it´s just a bit slow and takes some time until the image shows up. I guess the person who emailed you has a slow computer and thought it doesn´t work because nothing happened for a while.
As for your presets, if you had seamless tiling turned off, they might look different because the submission wizard turns it on.
Private Message is "E-Mail" in the lower right corner of a post.
Burt
Random Old Guy
Gosh right in front of me. I was expecting an inbox of some sort. Thanks.
Ah, ok. The filter is a bit slow. I actually saw I left some dead ends and will have to fix or remove them - I had created a different but very nice ice effect somewhat by accident, started tweaking things, broke it and then couldn't get the effect back - lesson learned and now I save a backup before I make changes.
As for the difference in renderings it almost looks to me like the transparency and the edge filter in particular (or the layer mode it is applied with) render differently.
