mw_Studio Light_Stars by marwyn
http://filterforge.com/filters/11189.html
WOW! Like it much, and the preset 1 is very beautiful and well done, and 9 too, and also has many possible variations.
These will come extremely handy for a variety of lighting situations. I'll probably post some demos of this thing in use. smile:)
MKBreuer
MKBreuer
Filters: 47
Hy Skybase!
Thanks! I am delighted to read this.
And I be anxious to, what you do with it! smile:)
Just simple, but not simpler. (A.E)
I have found again this filter searching for another thing, and I still think that is very beautiful and colorful and gives lovely results.
Since this post came up... I think this is the intended method of use.
Handy!
Good idea Skybase, and well done, like it
And you have gave me an idea to use this filter to make square images to be used with the [C]uberism Mapped by uberzev
Yeah, these make nice light gels and also nice incandescence sources for lighting. smile:) Great 3D stuff. I think I can do some quick model light tests for these. I just realized I haven't done any.
Looks also handy for other kind of designs.
I have made this other design, that is based on the the first preset without the black circle, like it much how delicate and great the effect is done and the glow
Also like the idea of how the colors are made and how they are applied, interesting and useful
I just found again this awesome and beautiful filter that such lovely effect and after many years still love it much
by error I had an landscape loaded while loading this filter and discovered something interesting as I did not know you can extend the effect further away from the main circle and get other things
and what I mean that the effect goes much beyond the main circle is that experimenting and just only adding a scale component at the end of the filter got this incredible effect
and using preset 1 and only just modifying the settings of Frame Margin and Frame corners to zero you are able to get this awesome and amazing image shown below using a square source image (have not tested any of the other presets)
If I did not had by error the landscape image I would have never been able to discover that this filter can offer really much more than what was shown by default
So thinking about this maybe other filters also may hide hidden treasures and could be discovered just adding a scale component
I was tempted to test another preset and used preset 9 and the result is another beauty
and using prest 9 with the same scale value of 0,2 and modifying the setting of Ring Corners to zero you get squares
