AL_white edges by Lorenzen
http://filterforge.com/filters/8595.html
Like this one, I was looking for a filter that could find the edges and make a white border around it and found this one that works and also gives a nice good effect overall.
Although I have noticed that this is very variable and the effect is not the same and changes much depending on the photo and how is done, perhaps to get the desired effect the photo should be prepared for this filter, to get a better result, so if you are lucky with the source image you can get a good effect.
Change the EDGE Radius to a low amount to make the image sharper (specially on preset 1 if you do not like the blur effect)
smile8)
Also edges like this
Some tulips flowers
Although NOT all have this effect as I have said, you can get different effect depending on the source and this above are only a few of the many I have tried, and many of them does not work right with this filter.
Here are other kind of effect I have got
just try and see what happens and modify the settings if needed
some oranges converted
Andrew B.
Filters: 2
Looks interesting. Downloading now.
Andrew B. , good that you like it and find it interesting
Be aware that it does not work right with any image, you must modify the settings and make some different tests to get a good result
