After some time waiting and seeing all the beautiful examples made with this nice filter it is available to try it ourselves smile:)
I like how you have done it and the idea, and the results are unique as you like and want.
Thanks for making this and sharing it in the FF Library
and here is another nice example making colorful rectangles that mix very well and makes nice hue shadings and transparencies
another settings and now with 45 degree that looks also good and well
And by painting the background black or white you can mask easily the nice effect
Thanks! smile:)
Some top-secret work with a filter applied to it. Now it's a different piece of art.
Thanks smile:)
Nice works, specially the second one, like the mix of the blues and violets.
YES, surely that this filter does not depend in accurate and very defined sharp source images smile;) smile:D so you can try many ways to improve the original in different ways, and could use filters to change the colors and does not need to keep being recognizable the source to work right.
I think that this has a great potential and could be better than it seems
ALSO will have to see well HOW you have done the "magic" inside the filter and see better what is behind this
Part of the technique has been mentioned in part 2 of my basic video tutorial series: https://vimeo.com/43945541
The other half comes from my older "point and shoot" filter.
To speed the filter up, I removed several insignificant components.
lipebianc
FFF = Filter Forge Fan
Fantastic, Skybase!
(and very fast) smile:ff:
I agree with you Lipebianc, this is fantastic and awesome!!
Is really good how from a simple photo that has been selected carefully with the right colors and disrtribution can be converted to something special and totally different thanks to this filter.
And also the presets are very good too and easy, and here I have made some example with the same source image (shown a little on the left side) and using different default presets without any further modification.
Preset 2
Here is default Preset 3
Here is default Preset 4
Here is default Preset 9
Here is default Preset 12
This is the last one that shows a different result of the presets I have tried and furthermore can be then customized as you could want.
Like much the effects you can get with this filter
Here is default Preset 15
The presets are there just for formality. The true nature of that filter happens when you hit the next variant button. You'll never hit ugliness.
Well I know that the presets are just an example, although they have been very well done and there are 18 of them to choose (thanks) but of course also modifying and controling the settings you can get also very nice results as you want them
YES, is true that with this filter the "next variant" button works very well and as you have said, it does not give a bad result as it happens with many others filters
Although in this case I myself still prefer the presets or the manual modified settings, at least with the images I have tried it until now
and speaking of presets I want to show here some of them (well at least from the first smile8)
Filters: 712
Very good and useful filter.
5 years after, I still think that this is a really artistic and very good filter that can make really unexpected beautiful results and still love it
22 unregistered users.
