Now after the great and well done filter of ThreeDee Sine-O-Graph I wonder if then it could be possible some other complex geometric and mathematical constructions than are made by multipling and rotating the geometric shapes through many different points.
Here are some examples I have found, but there are MANY more.
These are some artworks made by the artist Jason Padgett and he owns the copyright This is shown only as example.
http://www.consciousness.arizona.edu/...adgett.htm
Hmm. Great ideas! Three of the four are fairly doable, the hand-shaped pattern type stuff will require a sensible way to input free-form paths. I do have some potential solutions for it.
Thanks for your comment ThreeDee, after looking at your great filter and the tests that you have been doing I thought that you would know if this could be possible or not.
I agree with you that the hand shape would be more difficult and give more problems because is NOT a straight and normal geometric shape as the other 3 ones.
I like also the idea of multipling ONE geometric effect into a multieffect with as on the first one that the center one is copied to another 6 positions more to make a 7 pieces shape.
4 years ago I put this thread and now, I can say that this may be really possible with the new FF 5 loops component and should be easier for the one that knows how to do it, as I do not know
I think that it could be done something like this, and wanted to put it back as a possible inspiration for anyone that may like it
Ghislaine has been the Queen and master of these kind of graphics.
13 unregistered users.
