I have seen a filter for photoshop that uses a technique called ‘orbit trapping’ to map an image into fractal space
http://www.subblue.com/projects/fractal_explorer This uses fractal data to position photo images as if they were shown using the fractal data positions, Sorry that I explains this badly, Here is better an example to show it
I had the crazy idea that perhaps this could be possible in some way to be done also as a FF filter, but really and probably this would not be able to build something like this. |
| Posted: February 24, 2012 3:42 pm | ||||||||||
It would be possiblr to make this effect using LUA scripts. I suspect it will be very slow though, because LUA is slower than hard coded components, fractals are notoriusly slow and there's no GPU acceleration involved.
In any case, I stand by my description above my logo |
| Posted: February 24, 2012 5:42 pm | ||||||||||
WHY I THOUGHT ABOUT MAKING A FILTER FORGE FILTER WITH THIS ?
In the already made filter plug in I have put above it works very well, BUT ONLY allows to put just ONE image and this is the one that is going to be repeated all over the fractal image, so I thought that as Filter Forge can use more than one when configuring it in the filter, probably this could be a solution for having more than one image as fractal source.
YES, you are right, Sphinx have already used LUA scripts for something like this, and as you say they are very slow, if fractals are already slow on hard coded components, in LUA would be even slower as you comment very well, and of course is the very important and essential thing that FF does not have any GPU acceleration
I HAVE TESTED IT MYSELF AND GPU IS ESSENTIAL FOR IT TO WORK I have just downloaded it and tested myself, and have found that if you do not use the GPU option, and leave only the CPU, it goes like a very slow motion movie and can´t really use it much, and is painful to use this way. Activating the GPU optimization is like putting an airplane engine to it, it goes very fast and ALL in full real time. SO THIS IS NOT POSSIBLE TO MAKE IN FF So after the test and the really HUGE difference between the NON GPU option, I must say that this is not possible to make in Filter Forge, and considering that this is hard code software, and not using LUA script that would be even slower. Sorry for suggesting this and not have thought that it would need GPU acceleration optimization
| Posted: February 24, 2012 10:34 pm | ||||||||||
Actually that could work well in FF.. I'll check it out
| Posted: February 25, 2012 5:58 am | ||||||||||
| Posted: February 25, 2012 7:48 am | ||||||||||
| Posted: February 25, 2012 8:52 am | ||||||||||
Good start!
| Posted: February 25, 2012 9:46 am | ||||||||||
I believed that this would not be possible and you have made me happy knowing I was wrong as you have showed here. WOW !! WOW !! Sphinx you have doen a GREAT work !!!
Excellent, beautiful and very good examples !!! What use has the PHP file that you have put in the link ??? Inside this file there are lots of texts from the FF FORUM !!!!
The MOST IMPORTANT question is HOW FAST it is to render in FF, because in Pixel bender is done in REALTIME and I do not think that in FF would not be possible. The only interesting thing to be able to choose the FF filter against the Pixel bender one is the ability to MIX more than one image in the fractal explorer, BUT it is has enough speed to be useful. |
| Posted: February 26, 2012 2:46 am | ||||||||||
Just click it
Nothing in FF is realtime, but the filter is quite fast by FF standards. The two images above were rendered in about 10 secs, 25 samples AA! The attached one rendered in 1 minute and it is set to the most expensive settings possible |
| Posted: February 26, 2012 4:44 am | ||||||||||
In that case, all I have to say is DAYUM!
Now how about upping this to the library? And having more than 1 pic? |
| Posted: February 26, 2012 6:18 am | ||||||||||
YES
That´s why I was asking because I know VERY WELL that NOTHING in FF is in realtime The time you have put is good and usable, BUT this time is RELATIVE and really not a good measure to know if it fast or not UNLESS YOU KNOW THE RESOLUTION OF THIS EXAMPLES The time you have measured is to make the 600 x 600 examples you have put above ? Taking the highest one you have put, if it takes 1 minute to make a 600x600 result, then: it would take 16 MINUTES to make a 2400 x 2400 (600x600 = 360.000 2400x2400 = 5.760.000 --> 5.760.000 / 360.000 = 16)
it would take nearly 45 MINUTES to make a 4000 x 4000
Making a 4000 x 4000 image with Pixel Bender Fractal Explorer in high quality using GPU activated it takes 1 SECOND |
| Posted: February 26, 2012 5:43 pm | ||||||||||
If I have choosen the highest quality is because on fractals reaching the infinite need to have a very good antialias to make them see well and good.
THE BIG DIFFERENCE IS TO HAVE MORE THAN 1 IMAGE What would be really interesting and useful and really be worth the time it would take to render is IF you could more than one image option, at least have 3 images to combine in the FF Fractal explorer (or better 5 if it possible) this would make the biggest and real difference and the reason to use this filter in FF versus using it in the Pixel Bender. Of course that if you do NOT own Photoshop CS4 or CS5, you will not be able to use Pixel Bender, so this would still be a good alternative even with only one image. |
| Posted: February 26, 2012 5:44 pm | ||||||||||
Wow. Very nice results. Also the original site is interesting. I like their videos.
SpaceRay, your new avatar is very nice too. |
| Posted: February 27, 2012 3:26 am | ||||||||||
Like I wrote, the timings are for the images I posted (click on the thumbnails to see the full resolution versions).
I will post a multi image version soon (I'm out of time atm.). It will use different images as the iterations progress.. |
| Posted: February 27, 2012 10:14 am | ||||||||||
Please, Is there any new news about this idea ?
Sphinx, have you done anything else with this ? Thanks |
| Posted: July 10, 2012 1:22 pm | ||||||||||
I asked in July about this and there has not been any news, and now in November I ask again
Please Sphinx: What happened to your filter about this topic? Do you have a little more time now or you are not interested in it anymore? |
| Posted: November 22, 2012 6:25 am | ||||||||||
Sphinx, Is there any possible news about this filter to be used with source images? This is really cool and awesome The link in the first post does not exist anymore, and laso are missing the images attached, now it takes you to ANOTHER different link, so do not be confused OR if anyone knows another software that is able to do this in the same way, maybe faster than FF, is important for me that the alternative software must use a GUI based mouse driven way to control and does not need to use any kind of programming or scripting |
| Posted: November 1, 2015 2:34 am | ||||||||||
