Hello,
I have just seen this beautiful seamless Typographic pattern
I want to ask if this would be possible to make in Filter Forge in some way. The first idea it comes to my mind is to make this with the Bomber but I do not know how to make that the letters are NEVER overlaid into the other as it happens normally in Bomber, OR as it happens also that they are very spaced and have large spaces between them. Also the problem is that bomber only accepts 5 shapes, and this pattern there is MORE than 5 different letters, so I would need to use at least 3 bombers components and mix them so at least there could be 15 different letters. As you can see in this thread you can use letters inside filter forge and with bomber http://filterforge.com/forum/read.php?FID=10&TID=9488 I am trying to use my own 5 Particles Bomber Snippet but can´t make that the fonts DO NOT MIX between them or be spaced to much and be tightly toghether |
| Posted: February 17, 2012 3:32 pm | ||
15 unregistered users.
