Andrew B.
Filters: 2
I want to make a filter in FF3. The filter has two possible outputs. Each one will come from a different blend mode component. I want to connect their outputs to a control that can do a/b switcher so the user can pick one or the other. Or two check boxes. Or something else that is not a continuous blend. And this will lead to the final result.
I've looked, and looked and looked, and I can't find a control that can accomplish this. Can someone help me?
Just use the switch component with a checkbox..Then use the re-mapper for the checkbox to reflect the different choices...Like this..
Andrew B.
Filters: 2
Thanks for the detail. I got it working. Now onto the next problem.
You are welcome.. smile:)
267 unregistered users.
