Hi everybody smile:)
I'm working on my 1st filter, so please be patient with me smile:D
As a part of the filter, I need to offset each channel indepandantly. I EXTRACT each channel, put it through an OFFSET control, and then BLEND the channels back togather. So far so good, but now I want the user to be able to control the X and Y offsets for each channel in both positive and negative values (right and left for X, up and down for Y).
My question is, what is the best way to have a user control that will allow me to do that? As far as I saw sliders don't have a negative value...
Thanks!
Hello Morgantao and welcome to the addiction..ahhh I mean fun.. smile:D
Take a look at this filter......I do that very thing......
http://www.filterforge.com/filters/9979.html
Set that one up perfectly for ya... smile:dgrin: lol...
I havent installed FF3 yet smile:|
Is there a way to do it in FF2?
Right now the only thing I can think of (other than using scripts maybe, which is not for me to get into just yet) is offsetting the channel using a constant high value, and then using another offset control with user input.
EDIT: OK, now that I have FF3 installed, I can see how easy it is - there are negative values too smile:D
It can be done in the same fashion in FF2....FF2 has the same components being used....This is for FF2... smile;) smile:)
xy offset.ffxml
Yep, Silly me. smile:D
After installing FF3 and looking at CFandM's anaglyph filter I realized there's a value control.
Also I now understand that I could have used a slider control with a remapper, instead of all the garbage I wrote in my last post smile;)
Thanks for the help!
smile;) smile:D
To late I posted there already.. smile:D smile:)
Glad you got it worked out thou. smile:) smile:hammer:
Hate to bump an old and dusty thread, but I have another question... smile;)
Is there a way to limit the Value control to be between [-0.5] and [0.5]?
I don't want the user to go beyond those values, because then the image is actually flipped.
