After making the 3d cube, then playing with the frame component smile:)
I thought I would post this. There may be this in a filter already but I thought I would put it up. Its a method of making a directional light on 3d objects, it uses the
profile gradient so it has 4 positions.
Heres the snippet
Basic Light Control.ffxml
Heres one with a soft light control of sorts.
Basic Soft Light Control.ffxml
onyXMaster
Filter Forge, Inc.
JFYI: there's a support for point lighting (infinitely distant light sources) in shader code (Surface type), just no UI for it.
Your lighting for _images_ is better in most cases though because it supports a variation of a spotlight instead of point lights.
Spotlight is what I was going for. In my opinion its more of a softer light than point lighting, in some instances. I still have yet to experiment with other types and ways of lighting with this method. Such as how it would react to an actual image. Maybe also incorporate full rotation. But I did use a variation of this in the Poker Chips filter for the bevel.
I did also submit this snippet smile:)
Here is another light snippet of sorts that I was messing with. Trying to get the light or kinda light to follow a shape.
Here is another pict
Heres the snippet if anyone is interested
More Lights.ffxml
Yes, we'll add the UI for point lights in future releases.
Will this be a toggle for Surface type filters or will you introduce a new filter type for this (as in 'Direct Light Surface' & 'HDRI Surface')?
The point lights can be used together with the HDRI sphere -- no need to introduce an additional filter type.
What if you want to use point lights (or simple lighting) without HDRI?
This would be great!!! A way around those undesirable reflection side effects..... smile:)
+1 smile:D
+1 also smile:loveff:
[...] A way around those undesirable reflection side effects..... Smile
How about this one: set Reflectivity to zero! smile;) smile:D
All kidding aside, maybe FF should provide a few hdri environments that are based on simple studio lighting (like these).
[mispost] smile;)
LOL.... I wish it were that simple smile:) I have to max reflectivity and height to get the glass that I want.....and have to take the good with the bad to get it.....
I was shunned and bannished the last time I brought that up smile:D LOL....
The third globe from left is exactly what I'm looking for....
a different shot of it in ambient.....
Here are some better examples.....
with the "reflection" images.....
and without the reflection images (from the lighting).....which is at the top of my FF wish list smile:D
I was also wondering if it would be possible to clean up the details in the existing FF lighting??? .....maybe just a straight horizon with a clear sky at different ambiences...... It's the reflection images of doors, windows, fences, and even people in the FF lighting that are creating the "dirty" side effects.....
