Steve555
Hi, I'm trying to adapt a tile filter I found in the library, which is based on the Tiles pattern, , and I need it to have only 1 tile horizontally and 2 vertically to fit a texture of size 256x512.
Unfortunately the Repeat H has a minimum of 1, so I end up with 2 horizontal tiles.
Is there a way to achieve this?
Thanks
jitspoe
Filters: 27
You could use the scale component and scale the width x2. That will disable seamless tiling, though. If you need seamless tiling, it's possible to scale using a gradient and the offset component.
Dmitry Sapelnikov
Filter Forge, Inc. AKA Egret
Filters: 5
It's not a problem at all. Don't forget that Filter Editor has Overrides panel (Filter->Overrides) where you can enforce seamless checkbox be enabled.
33,846 Registered Users
+13 new in 30 days!
+44 new in year!
