Lorenzen
Filter Forge addicted
Filters: 66
When I open a picture in FF and then open a selection, is there any way to change the blendmode??
Hmm.. blendmode between what? The selection you open will be available via the selection component in the external category. I think Filter Forge will change "behaviour" if the selection component is present in your filter..
Lorenzen
Filters: 66
Perhaps it's more the opacity between the open picture and the open selection. I'm not sure how to explain it smile:|
Tried to make a screenshot...
When inside the filter they appear as separate nodes that you use like two source images, except the selection node is grey-scale only
Lorenzen
Filters: 66
Ok that helps smile:) Thank you both for helping smile:)
266 unregistered users.
