Lorenzen
Filter Forge addicted
Filters: 66
I know, how to turn if off, when i make the filter, but when i use one of the other presets, it's on again. Is there a way to turn it off, so it stay off, also when I i restart FF??
if it's a filter you've downloaded you cant change the presets that exist. you can make new ones with the AA off or, you can alter the filter, which will put your altered filter in your 'my filters' category and you can then change the existing presets, but as long as you leave the downloaded filter in its original category you cant alter the existing presets. you can add new or alter the filter, but that's it.
it's actually something i've never understood about downloaded filters. it makes little to zero sense to have that limitation on the filters. since we can easily alter the filters why have this fixed preset thing?
Lorenzen
Filters: 66
It's a filter, I'm trying to make... It's with glitter, but when then AA is on, there's not much glitter on it smile:( So I want to turn it off.
ok, just go to the view or tools menu, i think it is, and just turn set AA to 0. then save the preset that way and it will be off every time you double click that preset.
Lorenzen
Filters: 66
Ok will do that smile:) Thank you very much for helping smile:)
you're welcome smile:)
26 unregistered users.
