mattcscz
mattcscz
hi i have another simple question, does a filter have to have the result as a filter type: surface in order to be converted to a map such as a bump?
Miavir
The Cat who walks through Worlds
It has to be a surface filter. Thats because the simple filter doesn't have a notion of 'height', and how can you have a bump map if you don't have height ? smile:D
In ancient Egypt, Cats used to be revered as Gods.
Cats have never forgotten this.
And rightly so.
mattcscz
mattcscz
oh i thought it could be done from light and dark smile:p thanks ahah
you can convert any image into a bumpmap. a bumpmap is simply a grayscale map that when used in another program, the values of black, gray, and white are given the significance of values in 'height'. thus, you can make any image into a bumpmap by simply converting it to grayscale. however, if you want FF to spit it out for you that way, then it's like angelboiii said smile:)
Miavir
then it's like angelboiii said Smile
I didn't know angelboiii is a cat smile;)
And rightly so.
erp! sorry bout that, miavir smile:)
