ednachman
When I click on "create a new filter" and then "open filter editor", I get the filter editor but not my original image. I get the message "must be connected." How does one get connected? Any help is appreciated
ednachman
Maybe a snapshot will help someone understand my problem
the 'must be connected' is referring to the node (the little green box to the left of 'source'. you have to plug in a component into that node. in the case of getting your image to show, you have to plug in an 'image componet', which can be found over on the right of the editor in the components list under 'external'. just open that part of the component's list and click and drag an image component onto the main part of the editor window. then, on the right or left (depending on how your options are set) click and drag on the little arrow on the side of that component and 'plug' it into that source node. that's the basic operation of all components within the editor. for more detailed help hit F1 for the help section, study the stuff on the wiki pages and use the forums, like you are. there's a TON of good info here.
and welcome to FF!
ednachman
Kraellin, Thank you for the help. I'm now going into FF FF(Full Force) Thanks again.
you're welcome smile:) have fun!
15 unregistered users.
