Kenny
Posts: 10 |
Hello,
I usually have to make headders for web pages, sometimes in just a plain color with a bit text etc to represent the site owner, any way. I like the attached image, many times i have to do something like this, and sometimes with rounded corners. Can any one create a simple filter to do this maybe using a hexi decimal, See how it is dark to bright with a big of texture behind it. http://www.brunositalianrestaurant.co..._r1_c4.jpg were one able to create something like this with a shadow and another back ground it could eaisly be a commercial filter. if the filter could also give concepts of web safe colors see this image http://www.atascapizza.com/css/img/footer.gif it is a small image due to the websafe colors, were the filter to offer choices of colorv along with corners along with the variant in color for the redish image as linked to above wow would be great and would be something I would pay more for. regards Kenny success is a stairway and not a doorway |
| Posted: February 10, 2010 2:25 pm | ||
hi kenny,
i didnt quite understand all of that, but i think i may have something for you, at least in a very simple version. however, you will need to have the beta of version II of filter forge to use this. some of the components i used are not found in version one so it wont work with that. but, the beta is still free to download and use, so try it out. attached is the filter. this will work both as a complete solid background or with an imported image with the gradient background. it shld be fairly intuitive. it may not be everything you wanted, but it's a start Gradient Background 1a.ffxml If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: February 10, 2010 9:49 pm | ||
24 unregistered users.
