Lucato
FF addicted
Hi folks, by using Bricks Component we get to use the 'Bevel Width' slider to bevel the bricks. I'm wondering how we can bevel the mortar instead? Maybe It's a new challenge and also a suggestion to FF team to implement a 'Bevel mortar' slider in the Bricks Component. smile:)
I tried a lot of combinations with others components and etc, but I didn't get any result. Anybody has some tip to share?
Thanks in advance folks.
Interesting I did get this so far.
Here is the snippet
Motar Bevel.ffxml
Lucato
FF addicted
Hey CFandM, you got It! Congratulations and thanks a lot for sharing It. Great solution! Thanks a lot.
Heres one with a little more control. The bricks and the bevel size at the same time.
Motar Bevel.ffxml
The cool thing is also with this is connecting the control and slider in the pict below gives bevel shape control. Also works with tiles component
Lucato
FF addicted
Hey CF, based on yours, this one you get to control the bevel of mortar and bricks. smile;) Check this out:
Motar_Bricks Bevel.ffxml
Lucato
FF addicted
Here is the image:
Lucato
FF addicted
Btw, and exchaging the subject a little, FF team would add one more 'Load attachment' input. One for image and other for ff file. So, we would post both in the same post. smile;)
Lucato wrote:
Here is the image:
Nice, just the little bit that I have played with this I know that the tiles also work in the same fashion smile:)
The others I have not tried yet.
Lucato wrote:
Hey CF, based on yours, this one you get to control the bevel of mortar and bricks. Wink Check this out:
Cool its a multi-effort filter.
I added to Motar_Bricks a bevel shape and bevel depth. smile:)
Heres a pict.
Here is the FF file.
Yep, that would be nice, but unfortunately the current version of the board doesn't allow multiple attachments (hopefully they'll implement this in future releases).
Lucato
FF addicted
I see, thanks. Maybe you can request that to them. smile;)
byRo
an Englishman in Brazil
I used three separate brick patterns:
Brick 1: Ordinary brick stuff;
Brick 2: Mortar width 0%, Bevel width 100%.
Brick 3: White / black - mortar / brick mask.
The trick is to use the outer part of Brick 2 as if it were the mortar bevel. Applying a levels adjustment with the white point set to the overal mortar width, the mortar bevel becomes a black / white gradient (nice to play with smile:D ).
Brick 3 is used to combine the "normal" Brick 1 with the mortar bevel from Brick 2.
Rô
byRo
and the filter.....
Mortar uvn Bricks.ffxml
byRo
More fun with brick bevels....
