ronviers
lighter/generalist
Notice how these sphere halves do not fit cleanly together. Does anyone know how to make them fit together perfectly?
shpereQ a.ffxml
@ronviers
tigerAspect
Filters: 9
You mean like this?
The trick is to do a perfect shape first, then use it to mask the heightmap. There's an extra step there to blur the mask so your smooth thresholds will work for masking. It's not perfect, the blur->threshold affects the edge a bit. Props to Betis for the basic shape method.
shpereQ a-Masking.ffxml
Hey Hey, Thought I'd drop in here to see what's cooking... <.< anyway, I'm not really following the "Masking of the Heightmap" thing, It's probably something I understand, but it's worded differently. Yeah... thanks for the props! smile:D
Hey Tiger, you should post more often, you seem to know some good techniques about FF, and we'd (I assume) love to have you on the forums more. smile:)
ronviers
lighter/generalist
Great idea! smile:D Why didn't I think of that. I still have a lot of work to do, it's coming along, but I'm too tired right now. There is something to be said for the old look but I will have to work out what to do about that.
Thanks a lot for taking the time to help.
YinYangNewShape.ffxml
@ronviers
ronviers
lighter/generalist
This one only took fifteen seconds on my crappy computer.
@ronviers
ronviers
lighter/generalist
Btw, I do realize that about half of those components can be deleted. This version has both the old way and the new way and I have not had time to go through and remove all those extra components. smile:|
The biggest problem it has now is that when the dots are made big they scoot too far to the inside. I had the problem corrected in the old version but I have not done it to this one yet, so it looks funny with big dots.
@ronviers
ronviers
lighter/generalist
Here is the final tigerAspect. Thanks again for your invaluable assistance. I will add you to the list of creators in the description smile:)
YinYang.ffxml
@ronviers
ronviers
lighter/generalist
Here is one of its many looks. smile:)
@ronviers
ronviers
lighter/generalist
Betis, I noticed when working with your filter that you designed your symbol to spin the opposite direction to mine. So I was curious to know if there is a right or wrong way for it to be oriented. I found this link that gives an explanation for how they think it should be.
@ronviers
----At some point waayyy back when the symbol was first created, that's the original ("right") way, flip it, and it still looks about the same really ha-ha. Or, you could put a switch if that's easy enough to do, and get the best of both worlds. smile:)
ronviers
lighter/generalist
I didn't think of putting a switch. You're right, it should not be that big of a deal. I guess I should put a switch for flipping the colors too. Thanks jffe smile:)
@ronviers
I just recently added a switch to mine too.
ronviers
lighter/generalist
This is the final, at least from me. I'm all burned out on yin yang.
YinYang.ffxml
@ronviers
ronviers
lighter/generalist
Here is the final version. I have added a slider to give better control over reflections. smile:)
@ronviers
11 unregistered users.
