While trying to figure out full rotation I made this filter here. No it does not have full rotation but it may be a start if no one has done this as of yet. It has zoom in and out plus some rotation. Heres some screens.
http://www.fileden.com/files/2006/6/7...tepre3.jpg
http://www.fileden.com/files/2006/6/7...Zoom.ffxml
Well I have been playing with this filter a little more and now have a full rotation. However this one does have some drawbacks
that need to be fixed. One thats not so bad is... A checkbox needs to be checked for rotate right or left since it only spins
halfway. From 0 to 180 to the right and from 180 to 360 to the left. The other thing is if a image bigger than the default limitation
is used it does not look correct but still rotates. Still looks cool thou.
Another drawback is the image zooms in and out while rotating. When it starts rotating the image zooms in then when it gets halfway into the
spin it zooms out back to the original size. The good part aside from rotating is just simply delete the image component and connect
whatever component or components you want to make rotate in its place. However there will be a checkbox and slider that will need to stay
in order for this to work. But I have not experimented with to many other combos in the images place. So have fun with this.
Rotate Zoom.ffxml
22 unregistered users.
