ronviers
The initial value if the gamma component is set to 30. Was that an arbitrary choice or is it significant in some way?
@ronviers |
| Posted: October 15, 2008 4:48 pm | ||||
The gamma component is zero by default here, however if you hook up a slider you get 30 as the slider is 30 by default..
You can see how the gamma input maps to conventional gamma ranges here: http://www.filterforge.com/more/help/...ction.html Your screen gamma is probably somewhere around 2.2, thus if you want to perform operations in linear space you need to configure the gamma to 1/2.2 = 0.4545.. and then finally before going into the result you reapply 2.2 gamma. However these values are in conventioal gamma ranges, and FF do not provide a mapping formula, only that table above Sticking to the closest values in that table, the first gamma should be just around -40, and the final gamma should be just around 40 if you want to perform adjustments etc in a more linear space.. (e.g. blurs look much better when applied in linear space) But I don't know whats going on under the hood in FF, it could very well be that they use internal conversion to linear space and then only for the preview displays and final result convert back to gamma 2.2 .... |
| Posted: October 16, 2008 4:31 am | ||||
ronviers
Sorry, I should have specified the gamma curve component. But your additional information answered the question anyway. It looks like from the table you linked to that 30 is about 2.2. I do not have any of my equipment set correctly now. Still trying to get a handle on it. I know enough to keep the grays neutral throughout the tonal range but that's about it. Thanks a lot @ronviers |
| Posted: October 16, 2008 4:36 pm | ||||
ronviers
Here is an interesting podcast that deals with Adobe's color management. Mostly within the context of After Effects and film but much of the theory applies to PS as well. They touch on your point about blurs looking better in linear. Plus they cover some practical tips for working with blend modes in linear 32bit float space.
Stu Maschwitz has a great blog. @ronviers |
| Posted: October 17, 2008 2:42 am | ||||
