rgoer
Hi FF peoples,
Let's say you have a profile gradient such as this:
And let's say you want to quantize that gradient into 8 by 8 blocks like this, with these exact pixel values in the quantized result:
The catch is that you want to quantize it using only an offset node. What would your H and V offset inputs look like?
(The reason I'm looking for a way to get this exact result by quantizing an input gradient rather than just creating the quantized result from the start via a step curve is: I want to eventually apply this kind of quantization to non-linear gradients)
edit: the exact pixel values in that result are:
[(1/64),(2/64),(3/64)..(8/64)]
[(9/64)..(16/64)]
[(57/64)..(64/64)]
I ain't gonna try and do it with one offset, but here it is with four offset steps.
Quantize 8x8.ffxml
rgoer
Wow, you rule. On a guess I changed the one percentage from -6.13 to -6.25 (half of one eigth) and the other from -43.88 to -43.75 (the remainder out of 50), and the results still seemed to work, so very cool.
One interesting bug has popped up out of this, though--working with large image sizes (2k*2k or larger) you will see weird border artifacts show up between quantized "cells" in the render preview unless you have the "view actual size preview" option enabled.
Glad you saw that. Math before morning coffee always carries a certain liability...
