So, I've been trying to create a filter which has some bendy pipes. I've been trying to figure out how to take a map input, and to bend it like shown. All my attempts have resulted in some pretty messy failures ...er ... 'learning opportunities.'
Does anyone have suggestions on how make a filter which performs the operation shown in the image?
For super-extra credit:
Would it be possible to do this operation over a tiled field? ie not just one bend, but over an area which might have multiple bends back and forth?
Obviously, you want to have the textures bend accordingly.
I would use the spherize/unspherize snippet, using one quarter of it, and just plain splice it together from three pieces.
It is possible to make it tile, but it is rather complicated; you'll have to semi-rebuild the spherize/unspherize snippet using the Tiles Component and put a control of how many tiles in that way. I did something similar recently for Rgoer for his spiral animation (I doubt you can make it tile with the "Size, Pixels" control).
You will have to divide the offset percentages in the spherize/unspherize snippet by the number of tiles to make it work. Division math can be done, and a snippet or a few exist on the subject.
And you would have to have at least one tiled component that controlled the selection of which bend angle to use, quantized for 90 and -90 degrees.
I also recall seeing a filter "the perfect arc," which attempted something similar (not tiled), but I'm not too familiar with it.
Here is "the perfect arc that 3d was talking about....
http://www.filterforge.com/filters/5079.html
Heres a bending idea that I had but it does not do arcs....Also here is the frame component with a bend that you need don't know if this would be handy for your filter or not...
bendy thing.ffxml
Thought about this for a minute when 3d brought up spherize/unspherize snippet..I used the circle bits from that and using the any angle rotate from Uber one can bend the line..
Heres the curve bending snippet...
bendy thing2.ffxml
Thanks for the filter. This is not quite what I had in mind. I want to use a map component and then bend it. Not just make a bent thing from scratch. (I'm assuming that it will require some clever use of the offset component.)
Made a snippet for this. Coming soon to a filter library near you.
Does this:
Hey, that's awesome!
Did you do it by using the any angle rotate snippet, and then blend it diagonally across the elbow?
No, it is done by spherizing and splicing so that the textures bend properly. Sort of like this (simplified):
Ah, I see. Clever.
So it bends in 90 degree increments?
The snippet just does that one bend that you see. You can either use the same methodology to do the bend the other way or rotate the whole thing around, depending on how you're putting your texture together. The snippet is in the library now.
However, this ain't half the challenge of making it tile, you're gonna have fun figuring that out...
(But don't worry, it's easier than solving the Rubik's cube.)
Hint: Check out Voldemort's Random Rotate Tile.
saurabhgayali
Saurabh Gayali
Filters: 84
Is it possible to give a screenshot tutorials for u guys.
Cause i have an older version of FF which doesnt allow me to use filters
can u mail me replies on [email protected]
coz i am less prone to check this site.
Thanks in advance
uglyboys,
why dont you just update your version if it's 'an older version'. updates so far have been free.
saurabhgayali
Saurabh Gayali
Filters: 84
i have tried even earlier.
The update isnt free.
It has a 30 days limitation!
that isnt the update; that's the demo, but it's also the commercial version. if you didnt have filter forge (FF), you would download the demo and install it. that is good for 30 days, but if you purchased it you would get a permanent cd/product key that you enter into the program and it makes it the final, commercial version. once you had that and if the demo you downloaded wasnt already the current version, you would use the update feature in FF to simply automatically update your current version.
now, if you already have FF paid for and installed and it's not a current version, you'd simply use the built in product update feature to make your version the current version.
but, if all you have is the demo installed and the 30 day trial has run out, you can apply for an additional 30 days by using the contact form here on the forums. if that is approved, that would give you a new product key to input and you'd then use that to make your version active again and then download the new version off the web page.
I've been working on creating a filter that bends a line at degrees other than 90.
So far I've made a really cluttered one based on ThreeDee's and using the Any Angle Rotate snippet that bends at any angle between 0 and 180. If you bend it past 180, you will see that the second half of the line gets cut off. Also at 45 degrees, a piece of the pipe can be seen at the bottom left corner.
Bend Snippet v2.ffxml
Here's a visual:
Thanks, this is very interesting and useful.
Cool, but not sure what the use would be.
Well, to bend things smile;) smile:D
you can also check my snippet in the library. i made a rainbow filter that 'bent' a bar and i seem to recall i made a snippet of that and put in the library.
16 unregistered users.
