Heres a tip that I should have followed. Check names before sending filters to make sure there is none the same or close to others. I sent a filter called neon nights and then looked at the filters and seen this one up.
http://www.filterforge.com/filters/572.html
So vladimir could you please disregard this filter and I will change the name and resend it.
Neon Nights
I renamed it to Evening Glow instead of Neon Nights.
Lucato
FF addicted
Wouldn't be cool if the FF doesn't allow to upload filters with the same name that was sent before? Like showing an message "This filter name already existe, please try a new one." and a input field to enter the new name to avoid coming back all stuffs just to rename the filter. Maybe not. smile:)
IONclad
man... I assumed making a duplicate name wasn't even possible. I'm gunna start checking the filters... but what about the ones in the que? No... a warning is important.
