Lady Fayre
Lady Fayre
Filters: 33
Hello smile:)
I'm pretty new to all of this so please bear with me. I want to use an image I created in Photoshop or by using my tablet and to make a filter from it. The thing is it does not appear. I have mostly got the lifebuoy sitting in the background of my filter/s, when I have saved them to my library and I don't want to use the lifebuoy or other image defaults as a platform all the time for my projects. Is there a way that you can upload to FF an image you have created and create a filter from it? How is this done? All I need to see is the finished result without something someone else has created in the background.
Many thanks,
"Its a far better thing"
~*~Lady Fayre~*~
----No choice there, as far as defaults go. You can just select *File*, *New Image* and set a blank or solid colored background to start with, or *File*, *Open Image*, to select an image of your own to work with at any time. The reason you can't save images with filters is obvious as far as the library is concerned, copyright.
Lady Fayre
Lady Fayre
Filters: 33
Thanks for clearing that up for me jffe. I understand about copyrights etc. Just I thought that creating something original was the way to go. Anyways, it is really helpful what you have said and I appreciate that. Thanks smile:)
~*~Lady Fayre~*~
36 unregistered users.
