ronviers
A user wants to use 'Stretch by Corners' filter on non-square images. So I made a special filter that allows the filter to be compressed on either the h or v. Then saved. And another filter that would load the output of the first filter as the image in Photoshop and the user's image as the selection – then the filter should behave as normal. Here is the output of the first pass along with the filter doing the compression.
![]() @ronviers |
| Posted: April 19, 2008 11:59 pm | ||||
ronviers
| Posted: April 20, 2008 12:00 am | ||||
ronviers
| Posted: April 20, 2008 12:01 am | ||||
ronviers
| Posted: April 20, 2008 12:02 am | ||||
ronviers
Just to be clear. I have the grayscale image loaded in PS as my image. I have the travel image copied to the selection buffer and open FF. Once inside FF I am getting confused about how to make it work.
Thanks for taking a look, Ron @ronviers |
| Posted: April 20, 2008 12:07 am | ||||
ronviers
Btw, just ignore the wonky border on the first filter - if I can get this working I will figure out a way to correct that.
@ronviers |
| Posted: April 20, 2008 12:09 am | ||||
ronviers
Sorry, should have searched the forum before I asked. Never mind.
@ronviers |
| Posted: April 20, 2008 1:39 am | ||||
so you found a solution |
| Posted: April 20, 2008 1:46 am | ||||
ronviers
Yes and no. I found out I have to do this in stand-alone mode and load the selection via the menus. But now I seem to have another problem. When I load the selection it does not have any color. I'm tired so I am probably just doing something silly. Here is a cap of what I mean. Can you think of why there it is not in color? ![]() @ronviers |
| Posted: April 20, 2008 2:00 am | ||||
It never is colour so it's not you
| Posted: April 20, 2008 2:02 am | ||||
ronviers
| Posted: April 20, 2008 2:03 am | ||||
is it the refraction doing it
| Posted: April 20, 2008 2:05 am | ||||
ronviers
I jsut realized why it looks so bad. It's because I saved it as a low quality jpg. I forget how great the ff math it. I will try with the highest res. I do not have a good feeling about how this is going. @ronviers |
| Posted: April 20, 2008 2:06 am | ||||
some where just recently last week [ uberor sphinxs or 3d sorry can't recall details will try and find ] had a thread about conquering non square
| Posted: April 20, 2008 2:10 am | ||||
ronviers
I do not think my approach is going to work. Here is what it looks like with a better quality image and it is still bad. Maybe one of the big brains will have an answer. I still do not know why the selection is not in color. ![]() ![]() @ronviers |
| Posted: April 20, 2008 2:37 am | ||||
| Posted: April 20, 2008 2:38 am | ||||
ronviers
Hey Carl, I got it working.
Woops - here is a better one Stretch by Corners knon-squarel.ffxml @ronviers |
| Posted: April 20, 2008 8:18 am | ||||
onyXMaster
Posts: 350 |
Selection isn't in colour, since "Selection" should be named "Selection mask" (think of Quick Mask in Photoshop, but gray instead of red one).
| Posted: April 20, 2008 12:20 pm | ||||
ronviers
bummer @ronviers |
| Posted: April 20, 2008 12:38 pm | ||||
17 unregistered users.
