why am I getting purple smile:?: and not grey
border.ffxml
Interesting question. I also want to know.
In this snippet this color appears from "Layer 1" in MULTIBLEND.
And that's why I usually trying to switch all colors which I don't use in MULTIBLEND to BLACK.
ssamm
Filters: 21
My guess:
In FF, the color information is still remembered as part of an image -- even when the alpha channel = 0. When you blur some image with transparency, it seems to also blur the alpha channel too, and then, thereby, exposes some of the colors on the other channels (because the alpha/transparency parts got blurred/reduced).
Maybe look inside my attached filter to see better what I'm trying to describe...
(And by the way, I'm not saying this is how it "should" be -- I'm just describing how it seems to be.)
So: Constantin's advice is sort of the way I would work with this kind of stuff. smile:)
blur and alpha0.ffxml
change those 3 colors still showing in your multiblend to all black and your final square will be black.
onyXMaster
Filter Forge, Inc.
Short comment: ssamm is right smile:)
Thanks everyone smile:) and SSaammm thanks very clear smile8)
- in a perfect world should this be the case smile:?:
152 unregistered users.
