i'm trying to make a filter that essentially bends a horizontal bar. i can make the bar just fine and bend the bar, but i cant seem to keep the bar from 'crimping' at the ends or bulging at the center as i add more bend. so, i'm posting a snippet of the filter in the hopes that some of the math geniuses here can help me out. the bar must bend, but it must keep a uniform thickness as it does. any help?
Perfect Arc 1.ffxml If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: February 7, 2008 2:24 pm | ||||
Maybe you can pull it off if you tweak byRo's un-spherify
| Posted: February 8, 2008 1:36 am | ||||
| ssamm |
It will be interesting if others find a good solution here.
I messed around and ended up thinking that maybe the vertical, offset map could use an extra top to bottom dimension (rather than just a left to right dimension). So I did a crude experiment with the frame component... (It's got it's problems, but was meant to show how maybe an extra top to bottom dimension might help.) ...But maybe there is a perfect, single, 2-D curve that will work here? Perfect Arc 1b.ffxml |
| Posted: February 8, 2008 1:37 am | ||||
ssamm, thank you for that. still not quite perfect, is it
i'll play around with the one you posted and see if i can get it any better. you're close, but right in the middle of the arcing you get a bad curve on the lower middle. not sure why. makes no sense to me, so far. and i'll look at the unspheriphy also. you certainly got it closer than i did, though. i think i understand why mine pinches, but dont know the solution to fix it i did try a wave curve and that works fairly well, but still not perfect. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: February 8, 2008 2:23 pm | ||||
ok ssamm, your filter gave me the clue i needed. i think i've got it now. we had an impure gradient. when i changed your sphere gradient to a strictly profile circular gradient, then i could fix it!
you'll notice in the attached that i had attempted to mask your curve with a duplicate curve to get rid of that bottom edge, but something was wrong and that was the clue. when i began to move the mask up and down at varying percentage values, it became obvious that the bar/arc was warping at different values because of the round gradient and that gave me the means to a solution... change the circular gradient! so, i'm attaching the work filter with no additional cleanups and re-maps of controls and masking. i'll clean it up later and probably publish it as a joint effort snippet. THANKS!!! Perfect Arc 1f.ffxml If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: February 8, 2008 4:15 pm | ||||
this will actualy be handy for a filter I've been working on but got stuck on - hope you publish soon because I'd alway prefer using the library snippet so due credit is given
| Posted: February 8, 2008 8:19 pm | ||||
hi carl. i'm going to go look and work on it now. dont know about the opposite direction, but probably. could probably rotate it to all four major directions. i wont put an any angle rotate on it, though. it needs an edge to work against...sort of. i can actually connect it all the way around into a circle, which is why i need to limit the controls or mask it and why an any angle rotate probably wouldnt be good here.
| Posted: February 9, 2008 12:30 am | ||||
ok, carl, i got it to flip in the opposite direction. but, not sideways. i added a few little extras also; nothing much, just a couple of tweaks. i'll probably submit it tomorrow, saturday (well, today, but later).
oh, i just remembered, it's now my birthday If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: February 9, 2008 2:46 am | ||||
Brillant, I hope I can get the rest of the idea to work properly
A BIG HAPPY BIRTHDAY TO YOU
you deserve a special one, cause your a top bloke |
| Posted: February 9, 2008 7:20 am | ||||
thank you
| Posted: February 9, 2008 9:17 am | ||||
ok, i've submitted it to the library, carl
| Posted: February 9, 2008 9:32 am | ||||
Can't wait to see the solution on this one...I didn't want to look...A Birthday surprise..hehe..
HAPPY BIRTHDAY CRAIG ![]() Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: February 9, 2008 10:29 am | ||||
thanks, CF
yes, it works nicely now and i've also submitted another new filter based on the snippet. hope it's not the same thing as carl was going to submit. mine is a new rainbow filter. both shld be up monday. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: February 9, 2008 11:41 am | ||||
Interesting......sorry I missed the fun.....
| Posted: February 9, 2008 2:52 pm | ||||
working on another one that uses this. it's an attempt to break steviej glass
| Posted: February 9, 2008 5:55 pm | ||||
I'm going to break them myself.....need to re-do alot of them.....
| Posted: February 9, 2008 10:56 pm | ||||
better get started, then. only 172 to go
| Posted: February 10, 2008 12:52 am | ||||
| ssamm |
I'm glad the idea was of some help, Kraellin. I look forward to seeing what might be done with this bending offset idea.
Happy Birthday, yesterday, too! |
| Posted: February 10, 2008 10:47 pm | ||||
thanks for the b-day wishes, ssamm
| Posted: February 10, 2008 11:10 pm | ||||
Happy belated B-Day, Craig!!!
I'm always the last to know anything.....so, is FF out of the beta trial period yet??? Steve
| Posted: February 15, 2008 2:50 pm | ||||
| Posted: February 15, 2008 8:54 pm | ||||
thanks, steve
and no, not out of beta yet and you'd better get off your butt and get your 3 HU's, as well ![]() If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: February 16, 2008 10:32 am | ||||
15 unregistered users.
