crispalomino
I have been having so much fun working with the wonderful filters created by the community. I am slowly grasping some of the things to do. This is using DrEvil's beautiful Leather Emboss filter. I added image nodes as well as working with heights and working the image (which is a photoshop stained glass piece I made using real scans of stained glass) to work with the height levels set in the filter.
My question is: is there a way to add one of the marvelous snippets from the library to another filter to play with its effects or do I need to rebuild from scratch as I am still trying to understand everything.
Thank you.
Mousewrites
Not life size.
To use snippits, you just copy the components you want in the snippit filter, close it, and then open your filter. When you hit paste, the components from the other filter pop in.
Then it's up to you to connect them up.
crispalomino
Thank you, Mousewrites. That worked great.
29 unregistered users.
