Mousewrites
Not life size.
Yup, it's been asked before, and I can't quite find the answer.
I'm trying to make a 'postage stamp' filter, and have most of it done, but works sporadically on non-square images.
Check out the edge snippet from the filter, and run it on a rectangle. The right edge of the stamp goes all wonky.
Any thoughts?
Stamp.ffxml
i believe 'postage stamp' has been done already. check the library.
Mousewrites
Not life size.
I searched 'stamp' and didn't get it. I'll look again, though. Thanks for the heads up.
(at least I'll be able to see how they did it!)
Mousewrites
Not life size.
Just looked again; nothing with postage or stamp. Do you have a link (maybe it's named something else?)
hmmm, no, i dont. i'm going strictly by memory here.
ok, i just checked also. i couldnt find it either. the closest i could some was this one: http://www.filterforge.com/filters/4762.html but that might give you a fix for your wonky edge.
i'd swear someone had done one on postage stamps, though... odd.
12 unregistered users.
