I'm looking for a curve min/max snippet - like the Math Op component, just with the operators "A > B" and "A < B" (well, just one of them would do..). I tried searching for this, but either I'm searching for the wrong terms or this snippet doesn't exist..
| Posted: November 9, 2007 5:20 am | ||
Maybe you could give an example of what you're trying to achieve?
| Posted: November 9, 2007 9:15 am | ||
if it's there, you're in the right area... curve ops. dont recall a greater than or lesser than one, off-hand, but might be there.
| Posted: November 10, 2007 12:04 am | ||
What I want is to combine different curves using a combine mode similar to the lighten blendmode, and then use the result as profile for e.g. noise modules. Using the math curve op with A + B, doesn't work well, because the source curves "affects each other" if you understand what I mean...
| Posted: November 10, 2007 10:35 am | ||
| ssamm |
Yeah, if I understand you correctly, I've wanted to do this with curves before too. I.e. Use the greater value for each point between two curves. (Or the opposite which would be like a darken blend.) But I never figured out a way.
I think I even requested it in the Feature Wishlist forum a while ago. |
| Posted: November 10, 2007 10:46 am | ||
33,846 Registered Users
+13 new in 30 days!
+44 new in year!
13 unregistered users.
