ronviers
lighter/generalist
Just for fun I wanted to separate the diffuse and color maps within FF so I could play around with them. So I came up with the attached snippet.
For it to be accurate luminosity would need to closely describe the amount of light reflected from a surface and that may be too simplistic. But let's say for a minute that it does; then whatever times luminosity that returns the original image should be the color map. Is that correct? Are the components I have labeled diffuse map and color map close approximations to the actual maps? smile:?:
Seperation Test.ffxml
@ronviers
11 unregistered users.
