I ran into a difficult problem: I want the source image to tile along with the size pixels. Anyone? Maybe it can be done using the kaleidoscope?
I'm making genuine Delfts blue tiles. I want to be able to create a wall of tiles (size/pixels) with the lifesaver displayed here and there (so not on each tile). Sort of like the image below but then scaled to the size of a tile. |
| Posted: October 19, 2007 5:54 pm | ||||||||
That's an interesting problem indeed. None of the existing 'tiling' snippets works correctly with 'size/pixels', AFAIK. Does anyone else hear 'challenge'?
Your delft tiles are looking excellently photorealistic, btw. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: October 20, 2007 4:10 pm | ||||||||
I don't think it can be solved in FF's current state. So it's something for the wishlist. Either a new component, or put this feature into the Tiles component, or add an extra mode to the Kaleidoscope component. I think the Tiles component would be the most logical place.
yeah... damn you stupid mac version |
| Posted: October 21, 2007 3:53 am | ||||||||
Yup, looks like it.
There was some talk about introducing a 'repeat' component, and also about the inherent speed issues it would have:
However, the above problem appears to be a result of the limitation of the 'Image' component. The image component could be considered to be hardwired to a 'Fixed' state (like the option on a frame component). What it needs is an option to turn this off, so it would properly repeat & tile with the 'Size, pixels' slider. I imagine this would be rather easy to implement, and it propably won't even incur the speed penalties Vlad mentioned in the quote above. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: October 21, 2007 5:44 am | ||||||||
I would suggest putting a single tile into Quasimondo's "Simple Tiling" filter.....then sync it and blend with the grout tile grid that you have.....
| Posted: October 21, 2007 2:27 pm | ||||||||
That doesn't work, that's the whole point here. Just open Quasimondo's snippet and hit the size/pixels slider, you'll see what I mean.
| Posted: October 21, 2007 4:11 pm | ||||||||
I know......it's the next best thing you can do.....since what you want is impossible until FF comes out with a proportional gradient profile in version 2......
| Posted: October 21, 2007 4:33 pm | ||||||||
