garbanzo
Filters: 58
Anybody know how to cut the work field in half without using a gradient? (half black and half white for example)
Thanks!
try a step curve with a tone curve (if i'm understanding what you're after here.).
Yeak, I would say the same thing.....desaturate and use either linear or step to create a straight vertical curve.....
ssamm
Filters: 21
I think you'll still need a gradient as a source for the tone curve...
Another method without a gradient (but is more complex) could be to use a perlin noise component with a very large scale and a stretch value of 100 (and angle of 90 if wished) and plug that into a threshold adjustment (with smooth = 0). Here you'll have to adjust the threshold amount and perlin noise parameters to get the black vs. white to cut exactly in half.
What's the matter with using a gradient, though?
garbanzo
Filters: 58
i want to be able to do this with an image of any dimensions, to cut it in half vertically or horizontally...
i've seen a snippet out there which makes a gradient that's not restricted to square images, maybe i'll just use that.
ssamm
Filters: 21
Yeah, the gradients do go weird on non-square images. And uberzev's Proportional Gradient snippet is a clever solution for the problem.
