Lucato
FF addicted
Hi folks, today I'm little weak to think. I'm not getting to do what I want, and I'd like to ask you a help. I'm trying to make an Image Component occupy just one area of the result and the rest be empty/white. (See image attached). How can I fit/make an image be the size of the area I want as shown in the image below?
Thanks in advance.
Plug the Image component into the input of Threshold which is currently red (either Low or High).
Oops, didn't notice that you need scaling as well... For scaling, you can use Quasimondo's or byRo's snippets.
Lucato
FF addicted
Thanks Vlad for the help. I'll check them out. Any further doubt I'll post here.
Quasimondo
Quasimondo
Filters: 32
Lucato
FF addicted
Hey Quasi, thanks for your help. That is a good one. I just forgot to mention that I'm trying to do a way where any square size I adjust as in your Profile Gradient (White Square) by changing values in the curves or gradients I get the result image as the same size too. I mean, not only 1/4. If It is bigger than 1/4 would resize the final image too. Anyway thanks a lot for your help, It will help me, and I'll leave here the challenge for any one. smile;)
11 unregistered users.
