Ron C
Just downloaded trial version and I'm trying to move the input image up and to the right one pixel. Can't seem to get OFFSET to work. Docs don't seem to help me either.
Thanks,
RONC
Ronald E Chambers
Try adjusting the Offset %, see pic below.
Ron C
JFFE,
Thanks for the response.
Will this change based on image size? It seems to be for tiling use.
Why doesn't OFFSET work like in PS? Could have EXTENDED OFFSET option if adding to PS setup.
RON C
Ronald E Chambers
the offset works on percentage and not pixels. but, it is floating point, so you might be able to get what you want that way.
15 unregistered users.
