voldemort
voldemort
Filters: 649
Okay Im really close I mean really close to getting a proper stepped tile that does
1-2-3-4
instead of
1-2-4-8
got a nasty migraine and so cant think straight but I know Im close can anyone help on this one
00000sdhjflksjdfkljsdSTEPTILE.ffxml
voldemort
voldemort
Filters: 649
sorry to bug you guys and take away from your own projects
only thing i can help with here is organizing things a bit. i cleaned out the loose threads and re-ordered things a bit. might make it easier to think with.
for an actual fix, this looks to be something more along uber's or byro's math lines.
voldes steptile rev 1.ffxml
I did the same thing.....but not having any luck getting the last part of it.....I will give it another shot later today.....
voldemort
voldemort
Filters: 649
its a frustrating one Ill tell you Im closer but really hard to think and im preaty bussy so not much time here maybe Ill get it yet -----dont hold your breath though
voldemort
voldemort
Filters: 649
well I figured it out finnaly after all this time since I started with FF
My wife took the kids to stay at grandmas since I had a migraine even though I wanted them to stay
but it did give me the opportunity to take some medicine and upon wakeing up I figured it out
For someone that prides himself on thinking outside the box and not confining my thinking --I had really gotten in a rut on this one and not truly looked at it from all angles
angles is the key
I kept primarily foccusing on the horizontal when the true key was altering the vertical only worked like a charm even the dividions are properly scaled
its a complete wreck in its current state about 50 dead ends that I had been exploreing
Ill clean it up and set aside an example section within the filter tommorow morning
sorry to have bugged you guys and
Kraelin
Steviej
I appreciate your effort and help
it personifies what I believe the FF comminity should be all about smile:)
Your a better man than I.....got close, but couldn't quite figure it out.....look forward to seeing how you got it..... smile:)
voldemort
voldemort
Filters: 649
Okay quick update I was cleaning it up when I noticed some artifacts on closer scrutiny
because I use the number 33.3 is my assumption since we cant use fractions 1/3
I can use the same basis to get it to work but it will no longer be a simple filter --the inner mechanics will be quite bulky and in essense just a cheat using masks--but it will work and should render really fanst anyhow ---Ill get to work on the revised edition a little later and submitt it tomorrow --im a little disheartend by the discovery of those artifacts...
Ill probably release both versions
one officially the other in this post later incase someone wants to look at the guts of the orriginal
Nice name smile:D
voldemort
voldemort
Filters: 649
Thanks --I tend to name my stuff in progress giberish till I figure out a name and start it with numbers so its allways at the top
unfortunatly there are about 150 at the top right about now just waiting for a little more love and attention
Ah, I looked for it and was wondering why it wasn't there this morning smile:)
voldemort
voldemort
Filters: 649
Sorry just about screamed out loud when I saw those artifacts --just dont have the heart yet to work on it so Im finishing up a few others
Ill make sure its submitted by tommorow morning --but it may originally be only a snippet since for now Im only implimenting one direction instead of all 4
Ill later submitt a full filter that allows all 4 directions
and like I said Ill submitt the original in this post even though its flawed
I know the feeling.....I usually discover the flaws in mine after they have been submitted smile;) smile:)
Working on this one was quite a lesson on things I didn't know.....curious to see where I was going wrong.....and how the story ends smile:)
voldemort
voldemort
Filters: 649
Well for starters the storry ends with me being bald from pulling out my hair
this is one Ive wanted to do since the beginning but waited till I felt I was a little capable first
so its been especcially frustrating
LOL..... smile:D Yeah, sometimes you can't get it when you're working on it.....and then it hits you after you have put it down for a while.....
voldemort
voldemort
Filters: 649
There is an update to this topic entitled --Im entitled to change my mind smile:)
I'm on my way smile:)
15 unregistered users.
